Document ID: c08300564
Version: 1
HP Consumer Notebooks - Computer cannot connect to a hotspot using a Bluetooth connection
Notice: The information in this document, including products and software versions, is current as of the release date.The document is subject to change without notice.
Release date : 05-Jul-2022
Last updated : 05-Jul-2022
DESCRIPTION
The computer is unable to connect to a hotspot using a Bluetooth connection. This occurs because the McAfee LiveSafe app does not consider Bluetooth connections to be a secure network connection.
SCOPE
Computers:
  • HP 15 Laptop PC
  • HP ENVY 17.3 inch Laptop PC
  • HP ENVY x360 15.6 inch 2-in-1 Laptop PC
  • HP Pavilion 14 Laptop PC
  • HP Pavilion 15 Laptop PC
  • HP Pavilion x360 14 Convertible PC
  • HP Pavilion x360 15.6 inch 2-in-1 Laptop PC
  • OMEN 16.1 inch Gaming Laptop PC
  • OMEN 17.3 inch Gaming Laptop PC
Operating Systems:
  • Microsoft Windows 11
  • Microsoft Windows 10 (64-bit)
RESOLUTION
To resolve this issue, follow these steps to reconfigure the computer IP address as a whitelisted IP address:
  1. Open the McAfee LiveSafe Console.
    Click the Start menu, find McAfee LiveSafe or double-click the McAfee icon in the system tray to open McAfee LiveSafe Console.
  2. Click the My Protection icon on the left panel, and then select Firewall underneath Protect your PC.
  3. Go to My Network Connections.
  4. Add a new IP Address range 192.168.138.0 - 192.168.138.255 with Network type as Home and Adapter Type as Wired.
Hardware platforms affected : HP ENVY x360 15.6 inch 2-in-1 Laptop PC (Gidget) Configurable Material, HP 15 Laptop PC (Langkawi) Configurable Material, HP ENVY 17.3 inch Laptop PC (Tiberius) Configurable Material, HP ENVY x360 15.6 inch 2-in-1 Laptop PC (Mel) Configurable Material, HP Pavilion 14 Laptop PC (Dezik) Configurable Material, HP Pavilion 15 Laptop PC (Strelka) Configurable Material, HP Pavilion x360 14 Convertible PC (Slinky) Configurable Material, HP Pavilion x360 15.6 inch 2-in-1 Laptop PC (Ducky) Configurable Material, OMEN 16.1 inch Gaming Laptop PC (Ralph) Configurable Material, OMEN 17.3 inch Gaming Laptop PC Configurable Material
Support Communication Cross Reference ID : IA08300564
HP Inc. shall not be liable for technical or editorial errors or omissions contained herein. The information provided is provided "as is" without warranty of any kind. To the extent permitted by law, neither HP or its affiliates, subcontractors or suppliers will be liable for incidental, special or consequential damages including downtime cost; lost profits; damages relating to the procurement of substitute products or services; or damages for loss of data, or software restoration. The information in this document is subject to change without notice. HP Inc. and the names of HP products referenced herein are trademarks of HP Inc. in the United States and other countries. Other product and company names mentioned herein may be trademarks of their respective owners.
