HP Z24m G3 QHD Conferencing Display Product Specifications
Panel
4Q8N9AA
Display panel type
IPS
Panel active area (W x H)
52.68 x 29.64 cm
Resolution
QHD (2560 x 1440)
Aspect ratio
16:9
Viewing angle (typical)
178° (horizontal); 178° (vertical)
Brightness (typical)
400 nits
Contrast ratio (typical)
1000:1
Response times
5ms GtG (with overdrive)
Pixel pitch
0.21 x 0.21 mm
Display features
On-screen controls; Anti-glare; IR webcam; Height Adjust/Tilt/Swivel/Pivot; Integrated speakers; HP Eye Ease; Integrated microphone
Onscreen controls
User controls
Brightness; Exit; Information; Management; Power; Input control; Menu control; Image; Color
Resolutions supported
Signal interface/performance
640 x 480; 720 x 400; 800 x 600; 1024 x 768; 1280 x 720; 1280 x 1024; 1440 x 900; 1600 x 900; 1600 x 1200; 1680 x 1050; 1920 x 1080; 1920 x 1200; 2560 x 1400
Video/other inputs/cables
Interface
HDMI; USB-C; USB port; DisplayPort
Ergonomics
Tilt and swivel angle
-5 to +20°; ±45°
VESA mount
100 mm x 100 mm (bracket included)
Physical security
Security lock-ready
Power
Input voltage
100 - 240 VAC 50/60 Hz
Power consumption
170 W (maximum), 38 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
53.83 x 19.5 x 48.93 cm
Dimensions (W x D x H)
62.5 x 14.1 x 38.7 cm
5.7 kg
What's in the box
What's in the box
DisplayPort™ cable; HDMI cable; VESA Mount adapter; Warranty card; Quick Setup Poster; 1 USB Type-C®️ to Type-C cable; AC power cord; Color calibration report
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Environmental
85% post-consumer recycled plastic; Low Halogen; Outside box and corrugated cushions are 100% sustainably sourced and recyclable; Contains Ocean-Bound recycled plastic; Designed with recycled metals
Certifications and compliances
Australian-New Zealand MEPS; BIS; BSMI; CB; CCC; CE; CECP; CEL; cTUVus; EAC; FCC; GS Mark; ISO 9241-307; KC/KCC; NOM; PSB; SEPA; TUV-S; VCCI; Vietnam MEPS; WEEE; ISC; Low blue light; South Africa Energy; ICE; UAE; Ukraine certificates
