Model name
HP LaserJet Tank 1502w Printer
2R3E2A
- ${title}
- ${title}
- ${title}
- ${title}
Product Specifications for the HP LaserJet Tank 1502w Printer (2R3E2A)
Product naming
What's included and accessories
What's in the box
HP LaserJet Tank 1502w Printer; HP Black Original LaserJet Tank Imaging Drum (introductory ~5000 page black toner yield provided), Power Cord, Setup Guide, Reference Guide, Regulatory/Support Flyers, USB Cable
Connectivity
Ports
Hi-Speed USB (compatible with USB 2.0 specifications); 802.11a/b/g/n (2.4/5 GHz) Wi-Fi radio + BLE
Wireless capability
built-in WiFi 802.11b/g/n (2.4/5GHz)
Environmental
Acoustic power emissions (active, printing)
6.3 B(A)
Recommended operating humidity range
30 to 70% RH
Recommended operating temperature range (Celsius)
17.5 to 25°C
Recommended operating temperature range (Fahrenheit)
63.5 to 77°F
Storage temperature range (Celsius)
-20 to 60°C
Storage temperature range (Fahrenheit)
-4 to 140°F
Environmental specifications
Recyclable through HP Planet Partners; Contains post-consumer recycled plastic
Memory
Memory
64 MB
Maximum Memory
64 MB SDRAM
Mobile printing capability
Mobile printing services
HP Smart App; Apple AirPrint™; Mopria™ Certified; Wi-Fi® Direct printing
Mobile printing compatibility note
[5] Wi-Fi Direct® footnote: Mobile device needs to be connected to Wi-Fi Direct® signal of a Wi-Fi Direct-supported AiO or printer prior to printing. Details at hp.com/go/mobileprinting. Wi-Fi Direct® is a registered trademark of Wi-Fi Alliance®.
Networking
Network protocols, supported
TCP/IP: IPv4; IPv6; LPD; SLP; Bonjour; WS-Discovery; BOOTP/DHCP/AutoIP; SNMP v 1/2/3;HTTP/HTTPS; UDP; IPP
Paper handling
Input capacity
Up to 150 Sheets
Standard input capacity (envelopes)
10 Envelope
Output capacity
Up To 100 Sheets
Media sizes supported (metric)
A6; A5; A4; No.10 Env; C5 Env; DL Env; B5 Env; B5(JIS); B6 (JIS); Officio 216 x 340; Custom
Media sizes supported (U.S. standard)
Letter; envelopes (No.10); Legal; Postcard; Double Postcard; Executive; Officio; Custom
Media sizes, custom (metric)
102 x 152 to 215.9 x 355.6 mm
Media sizes, custom (U.S. standard)
4 x 6 to 8.5 x 14 In
Media types
Plain paper, Heavy paper, Bond paper, Label, Light paper, Envelope
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Paper handling - duplexer
Recommended media weight, duplex (metric)
No Duplex support in this SKU
Recommended media weight, duplex (U.S. standard)
Physical dimensions
Maximum dimensions (W x D x H, metric)
348.7X390.5X214.8 mm
Maximum dimensions (W x D x H, U.S. standard)
13.73X15.37X8.46 in
Weight (metric)
6.2 kg
Weight (U.S. standard)
13.67 lb
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology; Instant-on Technology
Internal (built-in) Power Supply
Power supply
Rated Voltage: 110-127V, Rated Current: 5.2A, Frequency: 50/60Hz, RMN:L12543E, Rated Voltage:220-240V, Rated Current: 2.9A, Frequency: 50/60Hz
Power consumption
Active printing: 354w, Ready: 1.59w, Sleep: 0.46w, Manual Off: 0.05w, Auto Off/Manual On: 0.05w, Auto-Off/Wake on LAN: 0.4w
Print cartridges
Number of print cartridges
1 (black)
Replacement cartridges
HP 154A Black LaserJet Tank Toner Reload Kit (Yield ~2500 pages); HP 154X Black LaserJet Tank Toner Reload Kit (Yield ~5000 pages)
Replacement cartridges footnote
[4] Declared yields based on ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on?images printed and other factors. For details see http://www.hp.com/go/toneryield
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 600 x 600 dpi
Maximum print area (metric)
215.9 x 355.6 mm
Monthly duty cycle
Up to 25,000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
HP Auto-On/Auto-Off, HP Smart App
Regulatory specifications
Ecolabels
Blue Angel; EPEAT® Silver registered
Safety
IEC 60950-1:2005 +A1:2009+A2:2013; IEC/EN 62368-1:2014; CAN/CSA C22.2 No. 62368-1, 3rd Edition; UL62368-1, 3rd Edition; IEC 60825-1 3rd Edition (Class 1 Laser Product); EN 62479:2010 / IEC 62479:2010; Compliance of IEC 60950-1 standard considers all country deviations according to the most recent IECEE CB Bulletin; Complies with FDA performance standards for laser products except for conformance with IEC 60825-1 Ed.3.,as described in Laser Notice No. 56, dated May 8, 2019
Electromagnetic compatibility
CISPR32:2015 & CISPR 35:2016 /EN55032:2015 - Class B; EN 61000-3-2:2019; EN 61000-3-3:2013+A1:2019; EN 55035:2017; FCC Title 47 CFR, Part 15 Class B/ICES-003, Issue 6
Telecom compliance (fax capability)
Wireless: EU RED 2014/53/EU; ETSI EN 301 489-1 V2.2.3 / ETSI EN 301 489-17: V3.1.1; EN 300 328: V2.2.2 / EN301 893 V2.1.1/ EN300 440-1 V2.1.1; FCC Title 47 CFR, Part 15 Subpart C & E / RSS 247 Issue 1, 2015 & RSS 102 Issue 5, 2015; IEC 62311:2007 / EN62311:2008
Security
Security management
Secure Boot, Secure Firmware Integrity, Runtime Code Integrity, password protected EWS, secure browsing via SSL/TLS 1.0, TLS 1.1, TLS 1.2; TLS 1.0/1.1 disabled by default; OpenSSL version 1.1.1; Enable/disable Network ports; SNMPv1, SNMPv2, and SNMPv3, Community password change; Secure defaults, Encrypted data at rest, Active FW update, Admin password by default, Cipher & TLS selection; Account lockout; Secure Wi-Fi setup
System requirements
Minimum system requirements for Windows
Microsoft® Windows® 11, 10, 7 SP1: 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, Microsoft® Internet Explorer or Edge.
Minimum System Requirements for Macintosh
Apple® macOS v10.15 Catalina, macOSv11 Big Sur, macOS v12 Monterey; 2 GB HD; Internet required
Compatible Network Operating Systems
Windows Server 2008 R2 64-bit, Windows Server 2008 R2 64-bit (SP1), Windows Server 2012 64-bit, Windows Server 2012 R2 64-bit, Windows Server 2016 64-bit; Linux (For more information see http://developers.hp.com/hp-linux-imaging-and-printing)
Operating system (supported note)
Not supporting Windows® XP (64-bit), Windows Vista® (64-bit) and Windows 8, 8.1. Full solution software available only for Windows 7 SP1, Windows 10 and newer; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed. Windows RT OS for Tablets (32 & 64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
Manufacturer Warranty
Up to 3 years extended warranty upon registration within 60 days at www.hp.com/go/lasertank-warranty
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
