HP ENVY Laptop 13-ba1538TU Product Specifications
4X734PA
Intel® Core™ i5-1135G7 (up to 4.2 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2933 MHz RAM (onboard)
Video graphics
Intel® Iris® Xᵉ Graphics
256 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
1 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.69 cm
1.30 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours
Video Playback Battery life
Up to 16 hours and 45 minutes
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
Windows 11 Home
