HP Laptop 15s-fq4018ns Product Specifications
531C5EA
Intel® Core™ i7-1195G7 (up to 5.0 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
  • Intel® Iris® Xᵉ Graphics
  • Integrated
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 250 nits, 45% NTSC
MediaTek Wi-Fi 6 MT7921 (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
Audio
Dual speakers
FreeDOS
