50M63PA
HP Laptop 15s-eq2144AU
AMD Ryzen™ 5 5500U (up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores, 12 threads)
AMD Integrated SoC
8 GB DDR4-3200 MHz RAM (1 x 8 GB)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Audio
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop 15s-eq2144AU Product Specifications
Windows 11 Home
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
