4H4G6PA
OMEN by HP Laptop 16-c0135AX
AMD Ryzen™ 7 5800H (up to 4.4 GHz max boost clock, 16 MB L3 cache, 8 cores, 16 threads)
AMD Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
AMD Radeon™ RX 6600M Graphics (8 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ TLC M.2 SSD
40.9 cm (16.1") diagonal, FHD (1920 x 1080), 144 Hz, 7 ms response time, IPS, micro-edge, anti-glare, Low Blue Light, 300 nits, 100% sRGB
Realtek Wi-Fi 6 (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.1; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36.9 x 24.5 x 2.29 cm
2.36 kg
230 W AC power adapter
6-cell, 83 Wh Li-ion polymer
Battery life mixed usage
Up to 9 hours
Video Playback Battery life
Up to 9 hours
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; DTS:X® Ultra; Dual speakers; HP Audio Boost
- ${title}
- ${title}
- ${title}
- ${title}
OMEN by HP Laptop 16-c0135AX Product Specifications
Windows 10 Home
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
