Product Specifications for the HP LaserJet Tank MFP 1005w Printer (381U4A)
Product naming
Model name
381U4A
What's included and accessories
What's in the box
381U4A HP LaserJet Tank MFP 1005w Printer; HP Black Original LaserJet Tank Imaging Drum (~5000 page black toner yield provided), Power Cord, Setup Guide, Reference Guide, Regulatory/Support Flyers.
Connectivity
Ports
Hi-Speed USB (compatible with USB 2.0 specifications); 802.11a/b/g/n (2.4/5 GHz) Wi-Fi radio + BLE
Wireless capability
built-in WiFi 802.11b/g/n (2.4/5GHz)
Copy
Copy speed (black, normal)
Up to 22 cpm
Environmental
Acoustic power emissions (active, printing)
6.3 B(A)
Recommended operating humidity range
30 to 70% RH
Recommended operating temperature range (Celsius)
17.5 to 25°C
Recommended operating temperature range (Fahrenheit)
63 to 77°F
Storage temperature range (Celsius)
-20 to 60°C
Storage temperature range (Fahrenheit)
-4 to 140°F
Environmental specifications
Mercury-free
Memory
Memory
64 MB
Maximum Memory
64 MB SDRAM
Mobile printing capability
Mobile printing services
Apple AirPrint™; HP Smart App; Mopria™ Certified; Wi-Fi® Direct printing
Mobile printing compatibility note
[4] Wi-Fi Direct® footnote: Mobile device needs to be connected to Wi-Fi Direct® signal of a Wi-Fi Direct-supported AiO or printer prior to printing. Details at hp.com/go/mobileprinting. Wi-Fi Direct® is a registered trademark of Wi-Fi Alliance®.
Paper handling
Input capacity
Up to 150 sheets
Standard input capacity (envelopes)
Up to 10 Envelope
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A6; A5; A4; No.10 Env; C5 Env; DL Env; B5 Env; B5(JIS); B6 (JIS); 216 mm x 340 mm; Custom
Media sizes supported (U.S. standard)
Letter; envelopes (No.10); Legal; Postcard; Double Postcard; Executive; Officio; Custom
Media sizes, custom (metric)
102 x 152 to 215.9 x 355.6 mm
Media sizes, custom (U.S. standard)
4 x 6 to 8.5 x 14 in
Media types
Plain paper, Heavy paper, Bond paper, Label, Light paper, Envelope
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
368X390.5X255 mm
Maximum dimensions (W x D x H, U.S. standard)
14.5X15.37X10 in
Weight (metric)
7.9 kg
Weight (U.S. standard)
17.4 lb
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology; Instant-on Technology
Internal (Built-in) power supply
Power supply
Printer_110V; RMN:L12553A; Rated Voltage:110-127V; Rated Current:5.4A;Frequency:50/60Hz Printer_220V; RMN:L12553E; Rated Voltage:220-240V; Rated Current:3.0A; Frequency:50/60Hz
Power consumption
Active printing: 390w, Ready: 2.7w, Sleep: 0.51w, Manual Off: 0.05w, Auto Off/Manual On: 0.05w, Auto-Off/Wake on LAN: 0.5w
Print cartridges
Number of print cartridges
1 (black)
Replacement cartridges
HP 158A Black LaserJet Tank Toner Reload Kit (Yield ~2500 pages); HP 158X Black LaserJet Tank Toner Reload Kit (Yield ~5000 pages);
Replacement cartridges footnote
[3] Declared yields based on ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/toneryield
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 600 x 600 dpi
Maximum print area (metric)
215.9 x 355.6 mm
Monthly duty cycle
Up to 25,000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
Instant-on Technology, HP Auto-On/Auto-Off[1], HP Smart App[2]
Regulatory specifications
Regulatory model number
SHNGC-2101-01
Ecolabels
CECP; EPEAT® Silver India
Safety
IEC 60950-1:2005 +A1:2009+A2:2013; IEC/EN 62368-1:2014; CAN/CSA C22.2 No. 62368-1, 3rd Edition; UL62368-1, 3rd Edition; IEC 60825-1 3rd Edition (Class 1 Laser Product); EN 62479:2010 / IEC 62479:2010; Compliance of IEC 60950-1 standard considers all country deviations according to the most recent IECEE CB Bulletin; Complies with FDA performance standards for laser products except for conformance with IEC 60825-1 Ed.3.,as described in Laser Notice No. 56, dated May 8, 2019
Electromagnetic compatibility
CISPR32:2015 & CISPR 35:2016 /EN55032:2015 - Class B; EN 61000-3-2:2019; EN 61000-3-3:2013+A1:2019; EN 55035:2017; FCC Title 47 CFR, Part 15 Class B/ICES-003, Issue 6
Telecom compliance (fax capability)
Wireless: EU RED 2014/53/EU; ETSI EN 301 489-1 V2.2.3 / ETSI EN 301 489-17: V3.1.1; EN 300 328: V2.2.2 / EN301 893 V2.1.1/ EN300 440-1 V2.1.1; FCC Title 47 CFR, Part 15 Subpart C & E / RSS 247 Issue 1, 2015 & RSS 102 Issue 5, 2015; IEC 62311:2007 / EN62311:2008
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
600 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Twain version
Version 2.1
Security
Security management
Secure Boot, Secure Firmware Integrity, Runtime Code Integrity, password protected EWS, secure browsing via SSL/TLS 1.0, TLS 1.1, TLS 1.2; TLS 1.0/1.1 disabled by default; OpenSSL version 1.1.1; Enable/disable Network ports; SNMPv1, SNMPv2, and SNMPv3, Community password change; Secure defaults, Encrypted data at rest, Active FW update, Admin password by default, Cipher & TLS selection; Account lockout; Secure Wi-Fi setup
System requirements
Minimum system requirements for Windows
Microsoft® Windows® 11, 10, 7 SP1: 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, Microsoft® Internet Explorer or Edge.
Minimum System Requirements for Macintosh
Apple® macOS v10.15 Catalina, macOS v11 Big Sur, macOS v12 Monterey; 2 GB HD; Internet required
Compatible Network Operating Systems
Windows Server 2008 R2 64-bit, Windows Server 2008 R2 64-bit (SP1), Windows Server 2012 64-bit, Windows Server 2012 R2 64-bit, Windows Server 2016 64-bit; Linux (For more information see http://developers.hp.com/hp-linux-imaging-and-printing)
Operating system (supported note)
Not supporting Windows® XP (64-bit), Windows Vista® (64-bit) and Windows 8, 8.1. Full solution software available only for Windows 7 SP1, Windows 10 and newer; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed. Windows RT OS for Tablets (32 & 64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
Manufacturer Warranty
One-year limited hardware warranty. For more info, please visit us at https://support.hp.com
