HP Laptop 15s-fq0064ur Product Specifications
3B3N5EA
Intel® Pentium® Silver N5030 (1.1 GHz base frequency, up to 3.1 GHz burst frequency, 4 MB L2 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2400 MHz RAM (1 x 8 GB)
Video graphics
  • Intel® UHD Graphics 605
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.79 cm
Starting at 1.65 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 45 minutes
Audio
Dual speakers
Windows 10 Home
