    Find Windows 11 and Windows 10 support help. Click here
Document ID: c07811328
Version: 1
HP ENVY 34-C0000 34 Inch All-in-One Desktop PCs - HP Command Center Focus Mode feature does not work
Release date : 07-Sep-2021
Last updated : 07-Sep-2021
DESCRIPTION
The Focus Mode feature in the HP Command Center does not work.
SCOPE
The information in this document applies to the following:
Computers:
  • HP ENVY 34-c0000 34 inch All-in-One Desktop PC series
Operating Systems:
  • Microsoft Windows 11
Applications
  • HP Command Center version 1.9.28.0 and earlier
RESOLUTION
To resolve this issue, perform the following steps to update the HP Command Center to the latest version.
  1. Click the Start icon.
  2. Locate, and then open the Microsoft Store.
  3. Click See more in the upper-right corner, and then click Downloads and updates.
  4. Locate HP Command Center, and then click Update.
    A restart might be required.
  5. Type Control Panel in the Search field.
  6. Click Programs and Features, and then locate the HP Command Center. Confirm that the version is later than 1.9.30.0.
  7. Close the Control Panel.
Hardware platforms affected : HP ENVY 34 inch All-in-One Desktop PC 34-c0000 (38M25AV)
Support Communication Cross Reference ID : IA07811328
