HP Laptop 14s-dq2025na Product Specifications
4H2X4EA
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
Intel® Iris® Xᵉ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
32.4 x 22.5 x 1.79 cm
1.82 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 45 minutes
Audio
Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Alexa; ExpressVPN (30 day free trial)
