HP ENVY x360 Convert 13-ay0045nn Product Specifications
4F660EA
AMD Ryzen™ 5 4500U (2.3 GHz base clock, up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores)
AMD Integrated SoC
8 GB DDR4-3200 MHz RAM (onboard)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.64 cm
1.32 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours and 15 minutes
Video Playback Battery life
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
