HP Laptop 15s-eq1028ua Product Specifications
2Z5P2EA
AMD 3020e (1.2 GHz base clock, up to 2.6 GHz max boost clock, 4 MB L3 cache, 2 cores, 2 threads)
AMD Integrated SoC
4 GB DDR4-2400 MHz RAM (1 x 4 GB)
Video graphics
  • AMD Radeon™ Graphics
  • Integrated
128 GB SATA 3 TLC M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, HD (1366 x 768), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
Audio
Dual speakers
Pre-installed software
ExpressVPN (30 day free trial)
