    Find Windows 11 and Windows 10 support help. Click here
HP Engage 16t FHD Monitor Product Specifications
Panel
2D9X0AA, 2D9V5AA
Display panel type
AHVA
15.6"
Panel active area (W x H)
34.42 x 19.36 cm
Resolution
FHD (1920 x 1080)
Aspect ratio
16:9
Viewing angle (typical)
178°
Brightness (typical)
400 nits
Contrast ratio (typical)
800:1
Response times
25ms on/off
Pixel pitch
0.1792 mm x 0.1792 mm
Display features
On-screen controls; Touch enabled; Low blue light mode; Dual speakers (2W per channel); Anti-glare
Onscreen controls
User controls
Brightness; Information; Management; Power control; Input control; Menu control; Image; Color
Resolutions supported
Signal interface/performance
640 x 480; 720 x 400; 800 x 600; 1024 x 768; 1280 x 720; 1280 x 800; 1280 x 1024; 1366 x 768; 1440 x 900; 1600 x 900; 1600 x 1200; 1680 x 1050; 1920 x 1080
Ergonomics
Tilt and swivel angle
–15 to +40°; no swivel
VESA mount
100 mm x 100 mm (bracket included)
Physical security
None
Power
Input voltage
100 - 240 VAC 50/60 Hz
Power consumption
65 W (maximum), 20 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
39.14 x 26.93 x 22 cm
Dimensions (W x D x H)
39.14 x 24.08 x 2.72 cm
15.4 x 9.48 x 1.07 in
Product dimensions with stand (W x D x H)
15.4 x 10.6 x 8.66 in
9.43 lb
What's in the box
What's in the box
Monitor; DisplayPort™ 1.2 cable (1.8 m/6 ft); Documentation; Power adapter; USB Type-C®️ cable (1.8 m/6 ft)
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Environmental
Recycled plastic cushions; Low Halogen
Certifications and compliances
Australian-New Zealand MEPS; BSMI; CB; CCC; CE; CECP; CEL; EAC; ENERGY STAR®; FCC; ISO 9241-307; KC/KCC; NOM; TUV-S; UL/CSA; VCCI; Vietnam MEPS; WEEE; China Energy Label (CEL) Grade 2; ICE
