HP Laptop 15-dw1161nia Product Specifications
49L32EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (2 x 4 GB)
Video graphics
Intel® UHD Graphics
1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, HD (1366 x 768), touch, micro-edge, BrightView, 220 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.78 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 8 hours and 30 minutes
Audio
Dual speakers
