    Find Windows 11 and Windows 10 support help. Click here
HP P24a G4 FHD Monitor Product Specifications
Panel
3Y0Q4AA
Display panel type
IPS
23.8"
Panel active area (W x H)
52.7 x 29.65 cm
Resolution
FHD (1920 x 1080)
Aspect ratio
16:9
Viewing angle (typical)
178º
Brightness (typical)
250 nits
Contrast ratio (typical)
1000:1
Response times
5ms GtG (with overdrive)
Pixel pitch
0.275 mm x 0.275 mm
Display features
Language selection; On-screen controls; Pivot rotation; Low blue light mode; Height adjustable; Brightness buttons
Onscreen controls
User controls
Exit; Information; Management; Power control; Input control; Menu control; Brightness+; Image; Color
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 1366 x 768; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
HDMI; USB port; VGA; USB hub; DisplayPort
Ergonomics
Tilt and swivel angle
-5 to +23°
VESA mount
100 mm x 100 mm
Physical security
Security lock-ready
Power
Input voltage
100 - 240 VAC 50/60 Hz
Power consumption
54 W (maximum), 16 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
54 x 21.15 x 46.39 cm
Dimensions (W x D x H)
54 x 6.02 x 32.33 cm
5.6 kg
What's in the box
What's in the box
Monitor; DisplayPort™ cable; HDMI cable; USB Type-A to B cable; Doc-kit; AC power cord
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Environmental
Low Halogen; TCO 8.0 certified
Certifications and compliances
CB; CE; EUP Lot-5; FCC; NOM (Mexico); S-Mark for Argentina; Low blue light; Mexico energy report
