25V74PA
HP Pavilion Laptop 15-eh0045AU
AMD Ryzen™ 5 4500U (2.3 GHz base clock, up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores)
8 GB DDR4-3200 MHz RAM (2 x 4 GB)
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal, HD (1366 x 768), micro-edge, BrightView, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX200 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader; 1 multi-format SD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 AC smart pin; 1 headphone/microphone combo
36.02 x 23.4 x 1.79 cm
Starting at 1.75 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 30 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by B&O; Dual speakers; HP Audio Boost
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion Laptop 15-eh0045AU Product Specifications
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
