HP Laptop 15-dw1210nia Product Specifications
23H98EA
Intel® Celeron® N4020 (1.1 GHz base frequency, up to 2.8 GHz burst frequency, 4 MB L2 cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 MHz RAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 600
1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, HD (1366 x 768), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
1.76 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 8 hours and 45 minutes
Dual speakers
FreeDOS
