HP Laptop 14-cf2017nia Product Specifications
402Z3EA
Intel® Pentium® Silver N5030 (1.1 GHz base frequency, up to 3.1 GHz burst frequency, 4 MB L2 cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2400 MHz RAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 605
1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
32.4 x 22.59 x 1.99 cm
1.51 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 9 hours and 45 minutes
HP True Vision 720p HD camera with integrated digital microphone
Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
