HP Laptop 17-by2600ng Product Specifications
2W6Q4EA
Intel® Celeron® N4020 (1.1 GHz base frequency, up to 2.8 GHz burst frequency, 4 MB L2 cache, 2 cores)
Intel® Integrated SoC
8 GB DDR4-2400 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics 600
256 GB SATA 3 TLC M.2 SSD
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal, HD+ (1600 x 900), anti-glare, 220 nits, 60% NTSC
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
41.48 x 27.22 x 2.45 cm
Starting at 2.41 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Camera with integrated digital microphone
Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
