HP ENVY x360 Convert 15-eu0078ng Product Specifications
46H78EA
AMD Ryzen™ 7 5700U (up to 4.3 GHz max boost clock, 8 MB L3 cache, 8 cores, 16 threads)
AMD Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
  • AMD Radeon™ Graphics
  • Integrated
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX200 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate; 1 HDMI 2.0b; 1 AC smart pin; 1 headphone/microphone combo
35.9 x 22.82 x 1.84 cm
1.86 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 11 hours and 30 minutes
Video Playback Battery life
Up to 11 hours
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
HP Audio Switch; HP Connection Optimizer; HP Command Center; HP QuickDrop; OMEN Gaming Hub; HP Display Control
McAfee LiveSafe™; 1-month Adobe free trial offer
Pre-installed software
Alexa; ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
