    Find Windows 11 and Windows 10 support help. Click here
OMEN 25i Gaming FHD Monitor Product Specifications
22J06AA
Display size
24.5"
Display type
IPS
Panel active area(inches)
21.4 x 11.91 in
Panel active area(cms)
54.37 x 30.26 cm
Brightness
400 nits
Pixel Pitch
0.2832 mm x 0.2802 mm
Input connector
1 HDMI 2.0 (with HDCP support); 1 DisplayPort™ 1.4-in (with HDCP support); 2 USB-A 3.2 Gen 1
Scan range (horizontal)
31-192 KHz
Scan range (vertical)
60-165 Hz
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:9
Static contrast ratio;Dynamic contrast ratio
1000:1
Response time
1ms MPRT
Tilt
-5 to +20°
External
Power consumption
53 W (maximum), 25 W (typical), 0.5 W (standby)
Power supply
100 - 240 VAC 50/60 Hz
Dimensions
55.75 x 9.23 x 33.3 cm
5.3 kg
