OMEN Laptop 15-ek1060TX Product Specifications
3V074PA
Intel® Core™ i7-10870H (2.2 GHz base frequency, up to 5.0 GHz with Intel® Turbo Boost Technology, 16 MB L3 cache, 8 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal, FHD (1920 x 1080), 300 Hz, 3 ms response time, IPS, micro-edge, anti-glare, 300 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.25 cm
Starting at 2.36 kg
200 W Smart AC power adapter
6-cell, 70.9 Wh Li-ion polymer
Battery life mixed usage
Up to 6 hours and 15 minutes
Video Playback Battery life
Up to 8 hours and 30 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; DTS:X® Ultra; Dual speakers; HP Audio Boost
