HP 285 and 295 G8 Microtower PC Specifications
Product image
Operating systems
Feature
Preinstalled Windows
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 is automatically updated, which is always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Preinstalled (other)
FreeDOS 1.2
Processors
Feature
AMD Ryzen 7 PRO 5750G
4.6 GHz Boost
16 MB cache
AMD Ryzen 5 PRO 5650G
4.4 GHz Boost
16 MB cache
AMD Ryzen 3 PRO 5350G
4.2 GHz Boost
8 MB cache
AMD Ryzen 7 5700G
3.8 GHz Base frequency, up to 4.6 GHz maximum boost clock
20 MB cache and 8 cores
AMD Ryzen 5 5600G
3.9 GHz Base frequency, up to 4.4 GHz maximum boost clock
19 MB cache and 6 cores
AMD Ryzen 3 5300G
4.0 GHz Base frequency, up to 4.2 GHz maximum boost clock
10 MB cache and 4 cores
AMD PRO565
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Memory
Feature
Type
DDR4 3200 (transfer rates up to 3200 MT/s)
Maximum
32 GB
Number of slots
(2) DIMMs
Configurations
4 GB DDR4-3200 UDIMM NECC (1 x 4 GB)
8 GB DDR4-3200 UDIMM NECC (1 x 8 GB)
8 GB DDR4-3200 UDIMM NECC (2 x 4 GB)
16 GB DDR4-3200 UDIMM NECC (1 x 16 GB)
16 GB DDR4-3200 UDIMM NECC (2 x 8 GB)
32 GB DDR4-3200 UDIMM NECC (2 x 16 GB)
Graphics
Feature
Integrated
Radeon Vega Graphics
Discrete (sold separately or as an optional feature)
AMD Radeon RX550X 4GB DP and HDMI Graphics card
AMD Radeon R7 430 2GB DP and VGA Graphics card
AMD Radeon 520 1GB DP and VGA Graphics card
High-definition (HD) content is required to view high definition images.
Networking/Communications
Feature
Ethernet
Integrated 10/100/1000M GbE LAN
WLAN
Realtek 802.11ac (1x1) WiFi and Bluetooth 4.2 Combo
Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Storage
Feature
SATA 3 (8.89 cm (3.5 in) or 6.35 cm (2.5 in))
500 GB 7200 RPM SATA Hard Disk Drive
1 TB 7200 RPM SATA Hard Disk Drive
2 TB 7200 RPM SATA Hard Disk Drive
Solid state drives (SSD)
128 GB M.2 PCI NVMe SSD
256 GB M.2 PCI NVMe SSD
512 GB M.2 PCI NVMe SSD
Optical disk drive
DVD-ROM 9.5 mm
DVD-Writer 9.5 mm
Actual speeds might vary. Double Layer media compatibility varies widely with some home DVD players and DVD-ROM drives.
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 10) is reserved for system recovery software.
Audio
Feature
Type
Realtek ALC3601
Microphone/headphone combo jack
Yes (front)
Audio ports
Rear side Line-in/ Line-out
Standard internal speaker
Yes (2 Watts)
Keyboards and pointing devices
Feature
Keyboards (optional or add-on feature)
HP PS/2 Business Slim Keyboard
HP 125 Wired Keyboard
HP Wired Desktop 320K Keyboard
HP 225 Antimicrobial Wired Keyboard
Mice (optional or add-on feature)
HP PS/2 Mouse
HP USB wired optical mouse
HP 128 Laser Wired Mouse
HP 125 Wired Mouse
HP 225 Antimicrobial Wired Mouse
Ports/slots/bays
Feature
Front I/O ports
(2) USB 2.0 ports
(1) Microphone/headphone combo jack
(2) SuperSpeed USB 3.2 Gen 1 Type-A ports
(2) SuperSpeed USB 3.2 Gen 2 Type-A ports
SuperSpeed USB 5 Gbps signaling rate = USB 3.2 Gen 1. SuperSpeed USB 10 Gbps signaling rate = USB 3.2 Gen 2.
Rear I/O ports
(2) USB 2.0 ports (optional)
(1) Ethernet/RJ-45 port
(1) Audio line-out
(1) Audio line-in
(1) VGA port
(1) HDMI port
(1) Serial ports
Internal in/out slots
(2) DIMMs
(1) PCIe x16
(1) PCIe x1
(1) PCI
(1) SATA for ODD
(2) SATA-HDD (2 x 3.5 in, could support dual 2.5 drive caddy)
(1) M.2 for PCIe SSD
(1) M.2 for WLAN
(2) PS/2 ports (optional)
(1) Parallel port (optional via PCIe x1 slot)
(1) 4x Serial port (optional via PCIe x1 slot)
(1) Internal Speaker (optional)
(1) Intrusion Sensor (optional)
Bays
(1) 9.5 mm external slimline ODD bay (optional)
(1) 8.89 cm (3.5 in) or 6.35 cm (2.5 in) internal HDD or bay
(1) 8.89 cm (3.5 in) or 6.35 cm (2.5 in) internal HDD bay (share bay)
Software/security
Feature
Preinstalled software (varies by country/region)
Dropbox
New users are eligible to get 25 GB of Dropbox space free for 1 year from date of registration. Internet service required and not included.
Buy Office (sold separately)
Xerox DocuShare (90-day free trial offer)
sMedio True DVD for HP
Netflix
Amazon
HP Documentation
HP JumpStarts
Audio Switch
HP Support Assistant
HP Setup Integrated OOBE
HP System Event Utility
McAfee LiveSafe
Free 1-year subscription of McAfee LiveSafe service included. Available in Latin America countries/regions only. Internet access required and not included. Subscription required after expiration.
Security
Security lock slot (locks sold separately)
(1) Intrusion sensor (not available for all models)
Trusted Platform Module (TPM) 2.0
Supported on systems preconfigured with FreeDOS, and enabled as default in BIOS setup menu if the system is dTPM.
Power
Feature
180 W
ENERGY STAR Libra2 EPA90 (Gold) Full range 115 V/230 V
310 W
SFF ENTL ENTL EPA90 (Gold) Full range 115 V/230 V
500 W
EPA90 (Gold) Full range 115V/230V
All power supplies are not available in every country/region.
Physical features
Feature
Chassis (H x W x D)
33.74 x 15.54 x 29.7 cm (13.3 x 6.12 x 11.7 in)
System weight
5.52 kg (12.17 lb)
Weight varies by configuration and components.
