    Windows 11 Upgrade Guide
HP Chromebook x360 14c-ca0005nb Product Specifications
3D8F0EA
Intel® Core™ i3-10110U (2.1 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 4 MB L3 cache, 2 cores)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (onboard)
Video graphics
Intel® UHD Graphics
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.15 x 20.6 x 1.79 cm
1.65 kg
45 W USB Type-C™ power adapter
3-cell, 60 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours and 45 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers
Chrome OS™
