HP ENVY x360 Convert 15-es0650nd Product Specifications
3Y4H4EA
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
Intel® Iris® Xᵉ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate; 1 HDMI 2.0b; 1 AC smart pin; 1 headphone/microphone combo
35.9 x 22.82 x 1.84 cm
1.82 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 17 hours and 45 minutes
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
HP Audio Switch; HP Connection Optimizer; HP Command Center; HP QuickDrop; OMEN Gaming Hub; HP Display Control
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
