HP Chromebook x360 14a-ca0005sa Product Specifications
321A6EA
Intel® Celeron® N4020 (1.1 GHz base frequency, up to 2.8 GHz burst frequency, 4 MB L2 cache, 2 cores)
Intel® Integrated SoC
4 GB LPDDR4-3733 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 600
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), touch, IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Keyboard
Full-size, ash silver keyboard
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 microSD media card reader
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.55 x 21.96 x 1.82 cm
1.49 kg
45 W USB Type-C™ power adapter
2-cell, 47 Wh Li-ion polymer
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Dual speakers
Chrome OS™
