OMEN Laptop 15-en0014nb Product Specifications
2Z9C6EA
AMD Ryzen™ 7 4800H (2.9 GHz base clock, up to 4.2 GHz max boost clock, 8 MB L3 cache, 8 cores)
AMD Integrated SoC
16 GB DDR4-3200 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), 144 Hz, 7 ms response time, IPS, micro-edge, anti-glare, 300 nits, 72% NTSC
Keyboard
Full-size, 1-zone white backlit, mica silver keyboard and 26-Key Rollover Anti-Ghosting Key technology
Intel® Wi-Fi 6 AX200 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.25 cm
2.47 kg
200 W Smart AC power adapter
6-cell, 70.9 Wh Li-ion polymer
Battery life mixed usage
Up to 7 hours and 30 minutes
Video Playback Battery life
Up to 7 hours and 45 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
