HP Laptop 15s-du2092TU Product Specifications
194B0PA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
4 GB DDR4-2666 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics
1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
15.6" diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Keyboard
Full-size, jet black keyboard with numeric keypad
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.75 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 5 hours and 15 minutes
Video Playback Battery life
Up to 6 hours and 15 minutes
HP TrueVision HD camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer
