    Windows 11 Upgrade Guide
HP 15-da2000 Laptop PC series (7CE72AV) Product Specifications
2L3G7EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Video graphics
  • Intel® UHD Graphics
  • Discrete
  • NVIDIA® GeForce® MX130 (4 GB GDDR5 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, anti-glare, 250 nits, 45% NTSC
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 USB 2.0 Type-A; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 9 hours
HP True Vision 720p HD camera with integrated digital microphone
Dual speakers
FreeDOS
