    Windows 11 Upgrade Guide
HP Spectre 15-eb0000 x360 Convertible Laptop PC (7MQ47AV) Product Specifications
2C7D2EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
16 GB DDR4-2666 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics
  • Discrete
  • NVIDIA® GeForce® MX330 (2 GB GDDR5 dedicated)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, 4K UHD (3840 x 2160), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
35.99 x 22.64 x 1.99 cm
Starting at 1.92 kg
90 W Smart AC power adapter
6-cell, 72.9 Wh Li-ion polymer
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 13 hours and 30 minutes
HP True Vision 720p HD IR camera with integrated dual array digital microphones
Audio by Bang & Olufsen, quad speakers, HP Audio Boost 2.0
Pre-installed software
Netflix
