    Apache Log4j Update
HP Notebook - 15-dw1033ur Product Specifications
1U2Z6EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 SDRAM (2 x 4 GB)
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
2.14 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 8 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
