1N7Y6EA
OMEN Laptop - 15-ek0011ne
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
8 GB DDR4-2933 SDRAM (2 x 4 GB)
Video graphics
512 GB Intel® SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD, 144 Hz, IPS, anti-glare, micro-edge, WLED-backlit, 300 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.25 cm
Starting at 2.36 kg
200 W Smart AC power adapter
6-cell, 70.9 Wh Li-ion
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
OMEN Laptop - 15-ek0011ne Product Specifications
FreeDOS
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
