HP ENVY x360 Laptop - 15-ed0013ur Product Specifications
1X2N6EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, 400 nits, 100% sRGB
Intel® Wireless-AC 9560 (2x2) Wi-Fi® and Bluetooth® 5 Combo (Supporting gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 AC smart pin; 1 headphone/microphone combo
35.8 x 23 x 1.89 cm
1.92 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 8 hours and 30 minutes
Video Playback Battery life
Up to 14 hours
HP Wide Vision HD Camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; 3 speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
