9WQ32PA
HP Notebook - 14s-cf2018tu
Intel® Celeron® N4020 (1.1 GHz base frequency, up to 2.8 GHz burst frequency, 4 MB L2 cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics
1 TB 5400 rpm SATA
35.56 cm (14") diagonal Full HD display
1 HDMI 1.4; 1 headphone/microphone combo; 1 RJ-45; 1 AC smart pin; 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate)
32.4 x 22.59 x 1.99 cm
Starting at 1.47 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Notebook - 14s-cf2018tu Product Specifications
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
