    Apache Log4j Update
HP Laptop - 14s-fq0100nb Product Specifications
1Q0J3EA
AMD Ryzen™ 5 3500U (2.1 GHz base clock, up to 3.7 GHz max boost clock, 4 MB L3 cache, 4 cores)
AMD Integrated SoC
16 GB DDR4-2400 SDRAM (2 x 8 GB)
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
32.4 x 22.5 x 1.79 cm
1.46 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 30 minutes
Video Playback Battery life
Up to 8 hours and 45 minutes
HP True Vision 720p HD camera with integrated dual array digital microphone
Dual speakers
Pre-installed software
Netflix; ExpressVPN (30 day free trial)
