HP Chromebook - 14a-na0500sa Product Specifications
2R571EA
Intel® Celeron® N4000 (1.1 GHz base frequency, up to 2.6 GHz burst frequency, 4 MB L2 cache, 2 cores)
Intel® Integrated SoC
4 GB LPDDR4-2400 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 600
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD, IPS, anti-glare, micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 microSD media card reader
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.57 x 21.85 x 1.78 cm
1.46 kg
45 W USB Type-C™ power adapter
2-cell, 47 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 45 minutes
Audio by Bang & Olufsen; Dual speakers
Chrome OS™
