    Apache Log4j Update
HP Laptop - 15s-du2042tx Product Specifications
1A6J7PA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Video graphics
  • Intel® Iris® Plus Graphics
  • Discrete
  • NVIDIA® GeForce® MX330 (2 GB GDDR5 dedicated)
1 TB 5400 rpm SATA
Optical drive
Optical drive not included
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.75 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer
