    Apache Log4j Update
HP Pavilion Gaming Laptop - 15-dk1043nq Product Specifications
1K9J0EA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (2 x 8 GB)
Video graphics
  • Intel® UHD Graphics
  • Discrete
  • NVIDIA® GeForce RTX™ 2060 with Max-Q design (6 GB GDDR6 dedicated)
  • 512 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
Starting at 2.23 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS
