HP Laptop - 15-dw2697nr Product Specifications
2Z783UA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
16 GB DDR4-2666 SDRAM (2 x 8 GB)
256 GB Intel® SSD
Optical drive
Optical drive not included
16.1" diagonal FHD, IPS, anti-glare, micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
1.78 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 6 hours and 15 minutes
Video Playback Battery life
Up to 7 hours
HP TrueVision HD Camera with integrated dual array digital microphone
Stereo speakers
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
