132X8EA
HP Pavilion - 15-cw1030nv
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
16 GB DDR4-2400 SDRAM (1 x 16 GB)
Video graphics
AMD Radeon™ Vega 8 Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
36.16 x 24.56 x 1.79 cm
Starting at 1.85 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 9 hours and 30 minutes
Video Playback Battery life
Up to 8 hours and 45 minutes
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion - 15-cw1030nv Product Specifications
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
