    Are you working from home?
HP Notebook 14s-dq1003ur Product Specifications
8KJ06EA
Intel® Core™ i3-1005G1 (1.2 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Intel® Integrated SoC
Video graphics
Intel® UHD Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal HD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
32.4 x 22.5 x 1.79 cm
1.46 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 45 minutes
Video Playback Battery life
Up to 10 hours and 15 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
FreeDOS
