    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-da0190ur Product Specifications
4MJ66EA
Intel® Core™ i3-7020U (2.3 GHz base frequency, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
Intel® HD Graphics 620
128 GB M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal HD SVA anti-glare WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.77 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 13 hours and 15 minutes
Video Playback Battery life
Up to 11 hours and 15 minutes
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS
