HP Pavilion - 14-ce3021ur Product Specifications
9MP13EA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
  • Intel® UHD Graphics
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Intel® Wireless-AC 9461 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 5 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
32.68 x 22.55 x 1.79 cm
1.6 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 9 hours
B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS
