    Fix Windows 10 Update Issues
    Are you working from home?
HP Spectre x360 - 13-aw0011ur Product Specifications
8RS71EA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB LPDDR4-3200 SDRAM (onboard)
Video graphics
Intel® Iris® Plus Graphics
1 TB Intel® SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal 4K UWVA BrightView micro-edge AMOLED multitouch-enabled edge-to-edge glass with anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% DCI-P3 (3840 x 2160)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 headphone/microphone combo
30.6 x 19.45 x 1.69 cm
1.3 kg
65 W USB Type-C™ power adapter
4-cell, 60 Wh Li-ion polymer
Battery life mixed usage
Up to 9 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 45 minutes
HP TrueVision HD IR Camera with integrated dual array digital microphone
BANG & OLUFSEN; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
