    Fix Windows 10 Update Issues
    Are you working from home?
Document ID: c06536383
Version: 1
HP Tilt Pen - The Tilt Feature No Longer Supported in Windows Ink Workspace
Release date : 14-Jan-2020
Last updated : 14-Jan-2020
DESCRIPTION
Beginning with GDR KB4505903 (OS version after 18362.267), the Windows Ink Workspace has been updated: the Sketchpad feature has been replaced by the Whiteboard feature. The tilt feature of the HP Tilt Pen was only supported by Sketchpad.
The remaining features are Whiteboard and Fullscreen snip which do not support the tilt feature.
This is due to a design change by Microsoft and does not indicate a problem with the HP Tilt Pen.
SCOPE
Software:
Microsoft Ink Space
Accessories:
HP Tilt Pen
Computers:
  • HP ENVY 13-ab000 Notebook PC
  • HP ENVY 13-ag0000 x360 Convertible PC
  • HP ENVY 13-ar0000 x360 Convertible PC
  • HP ENVY 13m-ag0000 x360 Convertible PC
  • HP ENVY 13m-ar0000 x360 Convertible PC
  • HP ENVY 15-dr0000 x360 Convertible PC
  • HP ENVY 15-dr1000 x360 Convertible PC series
  • HP ENVY 15-ds0000 x360 Convertible PC
  • HP ENVY 15-ds1000 x360 Convertible Laptop PC series
  • HP ENVY 15m-dr0000 x360 Convertible PC
  • HP ENVY 15m-dr1000 x360 Convertible PC series
  • HP ENVY 15m-ds0000 x360 Convertible PC
  • HP Spectre 13-ap0000 x360 Convertible PC
  • HP Spectre 13-aw0000 x360 Convertible PC series
  • HP Spectre 15-df0000 x360 Convertible PC
  • HP Spectre 15-df1000 x360 Convertible PC series
Operating Systems:
  • Microsoft Windows 10 19H1 (Version 1903)
  • Microsoft Windows 10 19H2 (Version 1909)
RESOLUTION
The UWP versions of Microsoft OneNote and Microsoft Snip & Sketch apps both can support tilt (when using the highlight marker pen).
Microsoft OneNote can be installed from the Microsoft store.
Microsoft Snip & Sketch can be installed from the Microsoft Store.
Hardware platforms affected : HP ENVY 13-ab000 Notebook PC, HP ENVY 13-ag0000 x360 Convertible PC, HP ENVY 13-ar0000 x360 Convertible PC, HP ENVY 13m-ag0000 x360 Convertible PC, HP ENVY 13m-ar0000 x360 Convertible PC, HP ENVY 15-dr0000 x360 Convertible PC, HP ENVY 15-dr1000 x360 Convertible PC series, HP ENVY 15-ds0000 x360 Convertible PC, HP ENVY 15-ds1000 x360 Convertible Laptop PC series, HP ENVY 15m-dr0000 x360 Convertible PC, HP ENVY 15m-dr1000 x360 Convertible PC series, HP ENVY 15m-ds0000 x360 Convertible PC, HP Spectre 13-ap0000 x360 Convertible PC, HP Spectre 13-aw0000 x360 Convertible PC series, HP Spectre 15-df0000 x360 Convertible PC, HP Spectre 15-df1000 x360 Convertible PC series, HP Tilt Pen
Support Communication Cross Reference ID : IA06536383
