HP EliteBook x360 830 G5 Notebook PC - Illustrated Parts
Computer major components
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Details about your computer, including model, serial number, product key, and length of warranty, are on the service tag at the bottom of your computer. See Labels for details.
Figure : Identifying the computer major components
Computer major component part numbers and their descriptions
Item
Component
Spare part number
(1)
Display assembly, touch screen:
220 nits
L56434-001
220 nits, WWAN
L56435-001
400 nits
L56436-001
400 nits, WWAN
L56437-001
400 nits, WWAN, anti glare
L56438-001
1000 nits, BrightView, WWAN, privacy
L56439-001
1000 nits, BrightView, privacy
L56440-001
1000 nits, WWAN, anti glare, privacy
L56441-001
(2)
Power button board (includes holder and cable)
L56451-001
(3)
Keyboard/top cover (includes keyboard cable):
For a detailed list of country codes, see Top cover with keyboard.
Non-privacy
L56442-xx1
Privacy
L56443-xx1
(4)
Metal USB port bracket (included in Bracket Kit)
L56447-001 (Bracket Kit)
(5)
Plastic I/O port bracket (included in Plastics Kit)
L56454-001 (Plastics Kit)
(6)
NFC board (includes cable)
L56453-001
(7)
TouchPad (includes TouchPad cable):
For use in models with NFC (includes NFC antenna)
L56457-001
For use in models without NFC
L56458-001
(8)
RTC battery
not spared
(9)
Fingerprint sensor (includes cable and gasket)
L56446-001
(10)
Card reader board
L56452-001
(11)
NFC interface board (includes cable)
L59058-001
(12)
System board (includes processor and replacement thermal material):
All system boards use the following part numbers:
xxxxxx-001: Non-Windows operating system
xxxxxx-601: Windows 10 operating system
Intel Core i7-8650U processor
L56433-xx1
Intel Core i7-8650U processor (On Storage Recovery [OSR])
L56432-xx1
Intel Core i7-8550U processor
L56431-xx1
Intel Core i5-8350U processor
L56429-xx1
Intel Core i5-8250U processor
L56430-xx1
Intel Core i3-8130U processor
L56428-xx1
(13)
Heat sink (includes replacement thermal material)
L56445-001
(14)
Fan
L56444-001
(15)
Solid-state drive EMI shield (included in Bracket Kit)
(16)
Solid-state drive (M.2):
2 TB, PCIe, NVMe, TLC
L60460-001
1 TB, PCIe, NVMe, TLC
L60457-001
512 GB, PCIe, NVMe, TLC
L60463-001
512 GB, PCIe, NVMe, TLC, self-encrypting drive (SED), Opal 2
L60462-001
512 GB, SATA-3. TLC, FIPS 140-2
L60461-001
256 GB, PCIe, NVMe, TLC
L60458-001
256 GB, PCIe, NVMe, value
L60459-001
256 GB, SATA-3, TLC, Opal 2
L60464-001
128 GB, SATA-3, TLC
L60456-001
(17)
WLAN module:
Intel Dual Band Wireless-AC 8265 802.11ac 2 × 2 Wi-Fi + Bluetooth 4.2 (non-vPro)
910264-852
Intel Dual Band Wireless-AC 8265 802.11ac 2 × 2 Wi-Fi + Bluetooth 4.2 (vPro)
918855-852
(18)
WWAN module:
Intel XMM 7360 LTE-Advanced (Cat 9)
L15398-002
Intel XMM 7560 LTE-Advanced Pro (Cat 16)
L27188-002
Intel XMM 7262 LTE-Advanced (Cat 6)
L35286-002
(19)
Memory module EMI shield (included in Bracket Kit)
(20)
Memory module (DDR4-2666):
16 GB
937438-852
8 GB
937236-852
4 GB
L10598-852
(21)
Battery (4-cell, 53 Whr)
L34449-002
(22)
Speakers (includes cable)
L56456-001
(23)
Bottom cover:
For use in models without WWAN
L56448-001
For use in models with WWAN
L56449-001
Mass storage devices
Mass storage part numbers and their descriptions
Component
Spare part number
L60460-001
L60457-001
L60463-001
L60462-001
L60461-001
L60458-001
L60459-001
L60464-001
128 GB, SATA-3, TLC
L60456-001
Miscellaneous parts
Miscellaneous parts and their descriptions
Component
Spare part number
AC adapter:
65 W Smart AC adapter (non-PFC, 4.5 mm) - EM
913691-850
65 W AC adapter (non-PFC, 4.5 mm)
710412-001
65 W AC adapter, USB Type-C, 1.8 m (non-PFC)
L32392-001
45 W AC adapter (non-PFC, 4.5 mm)
741727-001
45 W AC adapter, USB Type-C, wall mount, 1.8 m (non-PFC)
L32390-001
Screw Kit
L56455-001
Cable Kit
Figure : Identifying the Cable Kit components
Cable Kit part number, components, and their descriptions
Item
Component
Spare part number
Cable Kit, includes the following cables:
L56450-001
(1)
Power button board cable
(2)
TouchPad cable
(3)
NFC cable
(4)
NFC antenna cable
(5)
Card reader cable
Plastics Kit
Figure : Identifying the Plastics Kit components
Plastics Kit part number, components, and their descriptions
Item
Component
Spare part number
Plastics Kit, includes the following parts:
L56454-001
(1)
SIM tray
(2)
SIM insert
(3)
Fingerprint sensor insert
(4)
Smart card reader insert
(5)
Plastic I/O bracket
Bracket Kit
Figure : Identifying the Bracket Kit components
Bracket Kit part number, components, and their descriptions
Item
Component
Spare part number
Bracket Kit, includes the following parts:
L56447-001
(1)
USB bracket
(2)
Fingerprint sensor bracket
(3)
(4)
