Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion 15-dq1000 x360 Convertible PC - Components
Right side
Figure : Identifying the right-side components
Component
(1)
Drive light
(2)
Memory card reader
Reads optional memory cards that enable you to store, manage, share, or access information.
To insert a card:
To remove a card:
(3)
USB Type-C port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides data transfer.
note: |
(4)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High-Definition Multimedia Interface (HDMI) device.
(5)
AC adapter and battery light
(6)
Power connector
Connects an AC adapter.
Left side
Figure : Identifying the left-side components
Component
(1)
USB SuperSpeed ports (2)
Connect USB devices, such as a cell phone, camera, activity tracker, or smartwatch, and provide high-speed data transfer.
(2)
Vent
Enables airflow to cool internal components.
note: |
(3)
Power light
(4)
Power button
caution: If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button down for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options:
(5)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
warning: note: |
(6)
Security cable slot
Attaches an optional security cable to the computer.
note: |
Figure : Identifying the display components
Component
(1)
Internal microphones (2)
Record sound.
(2)
Camera
Allows you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
note: |
(3)
Camera light
On: The camera is in use.
(4)
WLAN antennas*
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
note: |
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
To access this guide:
Keyboard area
TouchPad
Figure : Identifying the TouchPad
Component
(1)
TouchPad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left TouchPad button
Functions like the left button on an external mouse.
(3)
Right TouchPad button
Functions like the right button on an external mouse.
Lights
Figure : Identifying the lights
Component
(1)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(2)
Mute light
Speakers and fingerprint reader
Figure : Identifying buttons, speakers, and fingerprint reader
Component
(1)
Speakers (2)
Produce sound.
(2)
Fingerprint reader (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
note: |
Special keys
Figure : Identifying special keys
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes specific functions when pressed in combination with another key.
(3)
Windows key
Opens the Start menu.
note: |
(4)
Action keys
Execute frequently used system functions.
note: |
(5)
num lock key
Alternates between the navigational and numeric functions on the integrated numeric keypad.
(6)
Integrated numeric keypad
A separate keypad to the right of the alphabet keyboard. When num lock is pressed, the keypad can be used like an external numeric keypad.
note: |
Bottom
Figure : Identifying bottom components
Component
Vent
note: |
Labels
The labels affixed to the computer provide information you may need when you troubleshoot system problems or travel internationally with the computer. Labels may be in paper form or imprinted on the product.
note:Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
Service label—Provides important information to identify your computer. When contacting support, you may be asked for the serial number, the product number, or the model number. Locate this information before you contact support.Figure : identifying the service label
Service label components Component(1)Product name(2)Model number(3)Product ID(4)Serial number(5)Warranty period -
Regulatory label(s)—Provide(s) regulatory information about the computer.
Wireless certification label(s)—Provide(s) information about optional wireless devices and the approval markings for the countries or regions in which the devices have been approved for use.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
