HP ProDesk 680 G4 Microtower PC - Components
Standard configuration features
Features may vary depending on the model. For support assistance and to learn more about the hardware and software installed on the computer model, run the HP Support Assistant utility.
Figure : HP ProDesk 680 G4 MT
Front panel components
Drive configuration may vary by model. Some models have a bezel blank covering the optical drive bay.
Figure : Identifying the front panel components
(1)
Slim optical drive (optional)
(5)
USB SuperSpeed port with HP Sleep and Charge*
(2)
Dual-state power button
(6)
USB SuperSpeed port
(3)
Hard drive activity light
(7)
USB SuperSpeed ports (2)**
(4)
Audio-out (headphone)/Audio-in (microphone) combo jack
(8)
USB SuperSpeed Plus ports (2)**
*Connects a USB device, provides data transfer, and even when the computer is off, charges most products such as a cell phone, camera, activity tracker, or smartwatch.
**Connect a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
When a device is plugged into the combo jack, a dialog box is displayed. Select the type of device that is connected.
Rear panel components
Figure : Identifying the rear panel components on a non-vPro computer system
(1)
Audio-out jack for powered audio devices
(6)
USB ports (2)
(2)
DisplayPort monitor connector
(7)
Audio-in jack
(3)
VGA port
(8)
RJ-45 (network) jack
(4)
Optional port
(9)
Serial port (select products only)
(5)
USB ports (2)
(10)
Power cord connector
When a graphics card is installed in one of the system board slots, the video connectors on the graphics card and/or the integrated graphics on the system board may be used. The specific graphics card installed and software configuration will determine the behavior.
The system board graphics can be disabled by changing settings in Computer Setup.
