HP ZBook Studio G5 Mobile Workstation - Components
Your computer features top-rated components. This chapter provides details about your components, where they're located, and how they work.
Right
Figure : Identifying the right-side components
Component
(1)
Memory card reader
Reads optional memory cards that store, manage, share, or access information.
To insert a card:
  1. Hold the card label-side up, with the connectors facing the computer.
  2. Insert the card into the memory card reader, and then press in on the card until it is firmly seated.
To remove a card:
  1. Press in on the card, and then remove it from the memory card reader.
(2)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
  warning:
To reduce the risk of personal injury, adjust the volume before putting on headphones, earbuds, or a headset. For additional safety information, refer to the Regulatory, Safety, and Environmental Notices.
To access this guide:
  1. Select the Start button, select HP Help and Support, and then select HP Documentation.
‒ or –
  1. Select the Start button, select HP, and then select HP Documentation.
When a device is connected to the jack, the computer speakers are disabled.
(3)
Vent
Enables airflow to cool internal components.
The computer fan starts up automatically to cool internal components and prevent overheating. It is normal for the internal fan to cycle on and off during routine operation.
(4)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High Definition Multimedia Interface (HDMI) device.
(5)
USB Type-C power connector and Thunderbolt™ ports (2) with HP Sleep and Charge
Connect an AC adapter that has a USB Type-C connector, supplying power to the computer and, if needed, charging the computer battery.
– and –
Connect and charge most USB devices that have a Type-C connector, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
– and –
Connect a display device that has a USB Type-C connector, providing DisplayPort output.
Your computer may also support a Thunderbolt docking station.
Cables and/or adapters (purchased separately) may be required.
(6)
Power connector
Connects an AC adapter.
(7)
Battery light
When AC power is connected:
  • White: The battery charge is greater than 90 percent.
  • Amber: The battery charge is from 0 to 90 percent.
  • Off: The battery is not charging.
When AC power is disconnected (battery not charging):
  • Blinking amber: The battery has reached a low battery level. When the battery has reached a critical battery level, the battery light begins blinking rapidly.
Left
Figure : Identifying the left-side components
Component
(1)
USB SuperSpeed port with HP Sleep and Charge
Connects a USB device, provides high-speed data transfer, and even when the computer is off, charges most products such as a cell phone, camera, activity tracker, or smartwatch.
(2)
USB SuperSpeed port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
(3)
Security cable slot
Attaches an optional security cable to the computer.
The security cable is designed to act as a deterrent, but it may not prevent the computer from being mishandled or stolen.
(4)
Vent
Figure : Identifying the display components
Component
(1)
WLAN antennas* (select products only)
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
(2)
Internal microphones (2)
Record sound.
(3)
Camera light (select products only)
On: The camera is in use.
(4)
Camera(s) (select products only)
Allow(s) you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
Camera functions vary depending on the camera hardware and software installed on your product.
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
‒ or –
Keyboard area
TouchPad
Figure : Identifying the TouchPad components
Component
(1)
TouchPad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left control zone
Textured area that allows you to perform additional gestures.
(3)
Right control zone
(4)
Near Field Communications (NFC) tapping area and antenna* (select products only)
Allows you to wirelessly share information when you tap it with an NFC-enabled device.
*The antenna is not visible from the outside of the computer. For optimal transmission, keep the area immediately around the antenna free from obstructions.
‒ or –
Lights
Figure : Identifying the top lights
Component
(1)
Power light
  • On: The computer is on.
  • Blinking: The computer is in the Sleep state, a power-saving state. The computer shuts off power to the display and other unneeded components.
  • Off: The computer is off or in Hibernation. Hibernation is a power-saving state that uses the least amount of power.
(2)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(3)
Fn lock light
On: The fn key is locked.
(4)
Mute light
  • On: Computer sound is off.
  • Off: Computer sound is on.
(5)
Microphone mute light
  • On: Microphone is off.
  • Off: Microphone is on.
(6)
Num lk light
On: Num lock is on.
(7)
Wireless light
On: An integrated wireless device, such as a wireless local area network (WLAN) device and/or a Bluetooth® device, is on.
On some models, the wireless light is amber when all wireless devices are off.
(8)
Sharing or presenting light
On: Sharing is on.
(9)
Call answer light
On: Call answer is on.
(10)
Call end light
On: Call end is on.
Button, speakers, and fingerprint reader
Figure : Identifying the top button, speakers, and fingerprint reader
Component
(1)
Power button
  • When the computer is off, press the button to turn on the computer.
  • When the computer is on, press the button briefly to initiate Sleep.
  • When the computer is in the Sleep state, press the button briefly to exit Sleep.
  • When the computer is in Hibernation, press the button briefly to exit Hibernation.
Pressing and holding down the power button results in the loss of unsaved information.
If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options.
  1. Right-click the Power meter icon and then select Power Options.
(2)
Speakers (2)
Produce sound.
(3)
Fingerprint reader (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
Special keys
Figure : Identifying the top keys
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes frequently used system functions when pressed in combination with another key. Such key combinations are called hot keys.
(3)
Windows key
Opens the Start menu.
Pressing the Windows key again will close the Start menu.
(4)
Action keys
Execute frequently used system functions.
(5)
Embedded numeric keypad
A numeric keypad superimposed over the keyboard alphabet keys. When num lk is pressed, the keypad can be used like an external numeric keypad. Each key on the keypad performs the function indicated by the icon in the upper-right corner of the key.
If the keypad function is active when the computer is turned off, that function is reinstated when the computer is turned back on.
(6)
Windows application key
Displays options for a selected object.
Action keys
An action key performs the function indicated by the icon on the key. To determine which keys are on your product, see Special keys.
  1. To use an action key, press and hold the key.
Icon
Switches the screen image among display devices connected to the system. For example, if a monitor is connected to the computer, repeatedly pressing the key alternates the screen image from computer display to monitor display to simultaneous display on both the computer and monitor.
Helps prevent side-angle viewing from onlookers. If needed, decrease or increase brightness for well-lit or darker environments. Press the key again to turn off the privacy screen.
To quickly turn on the highest privacy setting, press fn+p.
Decreases the screen brightness incrementally as long as you hold down the key.
Increases the screen brightness incrementally as long as you hold down the key.
Mutes or restores speaker sound.
Decreases speaker volume incrementally while you hold down the key.
Increases speaker volume incrementally while you hold down the key.
Mutes the microphone.
Turns the keyboard backlight off or on.
To conserve battery power, turn off this feature.
Turns the embedded numeric keypad on and off.
Turns the wireless feature on or off.
A wireless network must be set up before a wireless connection is possible.
Provides quick access to your Skype for Business calendar.
This feature requires Skype® for Business or Lync® 2013 running on Microsoft Exchange or Office 365® servers.
Turns the screen sharing function on or off.
This feature requires Skype for Business or Lync 2013 running on Microsoft Exchange or Office 365 servers.
  • Answers a call.
  • Starts a call during a 1-on-1 chat.
  • Places a call on hold.
  • Ends a call.
  • Declines incoming calls.
  • Ends screen sharing.
The action key feature is enabled at the factory. You can disable this feature by pressing and holding the fn key and the left shift key. The fn lock light will turn on. After you have disabled the action key feature, you can still perform each function by pressing the fn key in combination with the appropriate action key.
Bottom
Figure : Identifying the bottom components
Component
(1)
Vent
(2)
Speakers (2)
Produce sound.
Labels
The labels affixed to the computer provide information you may need when you troubleshoot system problems or travel internationally with the computer. Labels may be in paper form or imprinted on the product.
Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
  • Service label—Provides important information to identify your computer. When contacting support, you may be asked for the serial number, the product number, or the model number. Locate this information before you contact support.
    Figure : Identifying the service label
    Component
    (1)
    HP product name (select products only)
    (2)
    Model number
    (3)
    Product ID
    (4)
    Serial number
    (5)
    Warranty period
  • Regulatory label(s)—Provide(s) regulatory information about the computer.
  • Wireless certification label(s)—Provide(s) information about optional wireless devices and the approval markings for the countries or regions in which the devices have been approved for use.
